Posted 1/17/2008 10:35 (#285206) Subject: Spraying 32% N Through a JD 6000 Sprayer
Pulaski, TN
Those of you that have the 6000 sprayer or have owned one in the past, have you sprayed 32% through it? I would like to but have been told it won't work. Only problem I see is having to fill up often as it only has a 300 gallon tank. If you have had any problems doing this what were they. I have access to a John Blue pull sprayer I could use. Thanks!! Eddy
