| I have a T163 dryer that I feed with a 7" in your case I would use a 10" auger and slow it down a little if it seems like it fills too fast and is kicking in and running for only a minute or two mine usually runs for 3-5 minutes when it kick in and out. You will have to use and electric motor in your situation unless you really want to sit there on a tractor and run the PTO every time the dryer needs grain and I don't think you would want to do that. Dennis SEND | |
