Effingham, IL | I asked in a previous post about replacing the round lights in the fenders with rectangular halogens. Someone said to just replace the original round 4 1/2" sealed beams with replacement halogens. I ordered them from Shoup and was replacing them when I removed the outer light I found out it is a high/low beam ( has three terminals). Went to JD they only carry non-halogens. Where do I find a round, halogen, hi/low, 4 1/2" sealed beam? I can use the two terminal ones I have, but there will be no low beam and I'll have to run a new ground wire to them or it will mess up the lighting switch system. Thanks Craig | |
