| You lost clutch pack #3 (second from the rear on the speed output shaft) and reverse clutch (front clutch on the output shaft.)
Most likely no need to go into the range transmission; do a speed-range split, roll the speed housing out forward with the engine. You can inspect the range transmission thru the openings in the range housing, and air test the clutch packs to be sure.
Be sure to rebuild the TCV. | |
