Posted 2/29/2008 17:55 (#322691) Subject: Can't figure how to get press wheel bearing out of Haybuster drill
North Central Alabama
Has anybody ever changed out the 2 bearings on there press wheel on a Haybuster 107 no-till drill?I already have the new bearings and the outside diameter of the bearing is crowned in the middle.the press wheel is one piece and all metal and it looks to me if you try to push out the old bearing it will disfigure the metal that holds the bearing in.And the new bearing would be loose in the press wheel.
