NW Iowa | Brent is belt driven, unverferth is chain. brent has a adjustable auger, unverferth doesn't.
We ran a 1110 last year worked good. With the adjustable spout on the auger a person doesn't need the auger adjustment I feel. If you are going to be pulling around that much weight, I would suggest getting the biggest tires you can. We run the tandem cart. Really like the way it floats along through the field. But from what I've seen the big floaters work very well also.
If you have FWA on your 8300 you should be fine. | |
