Posted 3/19/2008 08:48 (#337329 - in reply to #337288) Subject: Re: Ours was the same way.
Southwest Missouri
If I recall correctly, we ran a 3 wire cable from the header to the combine. One is up. The next is down. The last is the power. We used 3 prong 110 plugs to connect the header to the combine. There just needs to be a switch in the cab to provide power or to turn it off. Then connect the wires from the header to the proper hydraulic valve.
