Search Forums | Classifieds (59) | Skins | Language
Changing fuel filter on GMC Duramax engine
Mike Shimek
Posted 3/20/2008 10:31 (#337864 - in reply to #337707)
Subject: You're doing it the hard way....
High Springs, Florida
If you just bend one of the A/C lines slightly, you do not have to remove anything. That is what I did on my 03. Not sure what the newer trucks look like under the hood, so this may not work.
It is not recommended that you fill the filter with fuel before installing it. The reason is that there is a possibility of getting some dirt or contamination on the "clean" side of the filter. You don't want ANY kind of dirt getting to those injectors.
Eric Merchant over on the dieselplace.com website sells SS bleeder screws. I think they are around $14.
Edited by Mike Shimek 3/20/2008 10:33
