Southern Alberta | Yup same as 530 our 9882 does the same thing put new selenoid on and it still does it sometimes not sure whats causing the solenoid to not open we have correct volts. Sent to dealer this winter for other work will loook up and see if it they diagnosed anything to fix it. We had to do our wheel bearing at about 3500 hrs also they were pitted bad and seals leaking. We have triples. | |
