Search Forums | Classifieds (4) | Skins | Language
magnum shifter
Guest
Posted 8/5/2006 20:20 (#33013 - in reply to #32966)
Subject: RE: magnum shifter
On my 7250, you always have to pull the lever down to the bottom and wait a few seconds for the accumulator pressure to go down. If using the clutch, you can select any F gear and then release the clutch. I don't know a simple way to not start in 1st when not using the clutch.
