Search Forums | Classifieds (54) | Skins | Language
add a picture
   Forums List -> FAQ & SupportMessage format
Jay NE Ohio
Posted 2/23/2015 11:29 (#4407585 - in reply to #4406571)
Subject: RE: add a picture
northeastern Ohio
It would be the same as a "Mapdot" (a map with a dot on your location). Usually, the best size is 100x100. Here are the directions:
Log into AgTalk if you're not already.
Click on the Control Panel link once you are back on the Main Forums page.
Scroll down to locate the box called Upload Mapdot.
Click on Browse
A small popup will appear.
Locate the mapdot file on your computer ( desktop ).
Click on it and then click Open
The file location will now be in the Upload Mapdot Box.
Click Go.
If the upload was successful, you will see your mapdot image imediately below the Set Mapdot URL box.
Hit Submit at the bottom of the page.
Your Mapdot is now up and running. You're Done.
