Bullseye Dryer and moisture controllers
HFR
Posted 8/6/2006 11:53 (#33185)
Subject: Bullseye Dryer and moisture controllers
Central Minnesota
Does anyone here have the Bullseye corn dryer controller that is manufactured in Ohio in use? We have a Stormor Top Dry system that is run on continous flow and our present controller(Optek RJE 2000) started giving us trouble last year and they no longer make that controller. I was wondering if the Bullseye would be a good replacement.Also the bin monitoring system. Do they work so you can get the moisture you want either by running bin fans at high humidity times to add moisture or low humity times to subtract moisture.
Edited by HFR 8/6/2006 11:54
