Search Forums | Classifieds (65) | Skins | Language
JD 2755 clutch
billybob
Posted 8/9/2006 20:13 (#34150 - in reply to #33933)
Subject: I have a 3255, simular problem.
68340
Mine to would want to grind going into gear. You had to wait like 20 seconds before it would not grind on a shift.
JD had a slave cyl. up date on the 3255. Still it is best if I bleed it twice a year.
Someone posted that they "bleed the system from the bottom up". I did not understand this. After I bleed it, it works great.
I have 3700 hrs and original clutch. It just depends on who is running the tractor on how long the clutch last.
