Search Forums | Classifieds (87) | Skins | Language
NH 650 Round Baler
MarkinMO
Posted 8/14/2006 22:14 (#35817 - in reply to #35722)
Subject: RE: NH 650 Round Baler
I have a NH 650 and the only time I've had this happen is if I accidently left the bale command in manual mode for some reason or if the tailgate latch indicator was flashing. The tailgate indicator was causing me problems a couple of times but I discovered the magnet came loose from it's base.
I was curious what type of wrap you use in your 650. I've only been able to use the black fastnet from New Holland. When I've tried the white it either wouldn't cut properly or wouldn't feed. Also, do you ever have problems with buildup below the duckbill and knife mechanism? The material is supposed to fall on thru but I think the baffle on mine may be bowed in and on certain types of hay causes it to clog up. This is my second year with this machine and I'm still trying to learn it. Haven't run into many others with a 650 with net wrap.
