Central Kansas | Phantom 3 set up for "Follow Me Mode", had 16 to 19 satellites, took it to the required height (100ft) had the altitude turn green, safe to fly GPS and have a screen that has 2 selection box's, one says "low battery", the other says "landing". ALL batteries were at full charge so I ignored the "low battery" tap on the other box and made a selection and tap on "apply" and get a message that says, "weak GPS signal", had the RC switch in the "F mode" and started to walk with the controller and the aircraft will not follow.
Tried it yesterday moving slowly with the pickup and it wouldn't follow either, had about 60% battery in the aircraft and thought maybe that was the reason but full battery today and still "no follow"
Any suggestions? Thanks | |
