Posted 2/19/2016 18:34 (#5123217 - in reply to #5122898) Subject: RE: locating drone after a crash
north east IN
Be carefull with the trackers that send you a text because the one I had worked great when I was walking around with it but when I laid it on the ground out in the field no cell service till I picked it off the ground. If you see your drone go down it will always be closer then you think
