Search Forums | Classifieds (19) | Skins | Language
Why False NDVI is not accurate....
   Forums List -> Drone TalkMessage format
BacNBlak
Posted 5/10/2016 17:16 (#5293126 - in reply to #5292691)
Subject: RE: Why False NDVI is not accurate....
Eastern Shore of MD
I was just flying a random mission to try some different settings; altitude and overlap. I really hadn't intended on getting the burn down and the pivot per se but when I saw the results, I'm glad I did. There is a difference between not being accurate or needing to be ground truthed and being completely a$$ backward as it was in this case lol.
I know exactly what you mean about there still being value but one could not try and make a prescription map with that image, that was my real point I guess. And I also think your right about ground truthing even with a proper NDVI set up. I wouldn't trust it blindly.
