North Central Kansas | Keep in mind that it may be a hardware problem specifically the wifi unit on the Vision 2. There is history of this module failing due to excessive heat. I had to replace the module in my Phantom 2 Vision+.
https://www.amazon.com/Phantom-Vision-Signal-Transmission-Module/dp/...
(costs more than the Vision2+ is worth)
The rebinding process after replacement can be a bit (quite a bit) tricky.
Edit: Sorry, this is in response to "PHANTOM VISION 2 CONNECTION ISSUE" below.
Edited by npalen 7/25/2016 12:50
