nc ks | One reason I want to use site mate is I use that software on my desktop to keep records, but I was afraid that the real time mapping wouldn't be as good and useful as Viper maps or Insight maps. I think you are confirming that Site mate maps don't track what booms are on so leaves a little to be desired compared to the others? Can Viper 2 software be run and Sitemate run in the background at the same time? The as applied acres according to booms switched on would be tracked in the EZ guide the way I understand it. I'm mainly worried if the map shows what booms were turned on and the overlap or skips. Can the Viper replace the 460 or does it still need it? thanks | |
