Search Forums | Classifieds (126) | Skins | Language
Starfire pigtail
lukerduke
Posted 9/18/2006 09:14 (#44673 - in reply to #44650)
Subject: Re: Starfire pigtail
MN
The Silver wedge box communicates on a deere 4/5 volt can bus system but the tcm that you installed in your receiver communicates on an ISO 2.5 volt system. So you will have to take the tcm out and install a jumper connector in its place. But if Autotrac is wanted there are some steps to take to make things compatible. You can convert from using the silver wedge box to using the brown mobile processor with a harness but then you have to make sure that your moisure sensor is a Dual Can moisture sensor meaning it will communicate on both a 4/5 volt system or a 2.5 volt. If its not Dual Can you will have to put a new moisture sensor on and then you have to change out the terminators on the Can Network from 4/5 volt to 2.5 volt.
