Search Forums | Classifieds (80) | Skins | Language
generic gps with greenstar
lukerduke
Posted 9/19/2006 08:58 (#44892 - in reply to #44793)
Subject: Re: generic gps with greenstar
MN
YOU CAN MAKE YOUR OWN HARNESS IF YOU FIND THE RS232 SIGNAL TRANSMIT AND THE RS232 SIGNAL GROUND COMING FROM YOUR GARMIN. THEN JUST HOOK UP THE TRANSMIT WIRE TO PIN F AT THE MOBILE PROCESSOR AND THE SIGNAL GROUND WIRE TO PIN C AT THE MOBILE PROCESSOR. THEN AS FAR AS THE SETUP OF YOUR RECEIVER YOU NEED TO HAVE THE FOLLOWING MESSAGES FROM THE NMEA 0183 GGA, GSA, AND RMC. ALSO SET THE BAUD RATE AT 4800, DATA BITS TO 8, PARITY NONE, STOP 1, AND FLOW CONTROL NONE. JOHN DEERE TO THE BEST OF MY KNOWLEDGE DOES NOT MAKE A HARNESS TO HOOK TO A NON DEERE RECEIVER BUT IF YOU CONTACT THE MANUFACTURER THEY MIGHT BE ABLE TO GET YOU A HARNESS THAT JUST Y'S INTO THE MOBILE PROCESSOR CONNECTOR.
