Search Forums | Classifieds (87) | Skins | Language
Merging Information in Apex
Bootsie Whitelaw
Posted 10/9/2006 11:00 (#49893 - in reply to #48990)
Subject: RE: Merging Information in Apex
Nutbush, TN
You should be able to edit the client, farm, and field name in "Setup."
Click on the incorrectly named field, click "Modify," and name it the correct name. If the "correct" name is not an option, setup a new client/farm/field and name it what it should be. Then click "Update." It should then merge the files together and put them in the correctly named field/farm/client.
Also check to see if you have the latest Apex update installed. A new update was posted this morning (Oct 9).
