NE SD | I see a scraper tractor set up with them that rolls through this area with them now and then. I'm guessing his reason is probably because if he were running big duals he would be wider than his pans. I can see where it would have it's ups and downs. One of the bad things would be if something happened replacing one of those would be significantly higher in price than replacing one 710 or 800 dual....also if you had one go flat when you had 50 acres left to do before that rain shower came through you'd have to stop rather than just keep going. Good?? Less tires to check pressure in. :) | |
