SC, MN. | your non-Deere GPS will work w/ the right cable adapter. On the run page it will show that you do not have GPS, however when you put the head down will the recording status change to ON? Go to info, harvest doc, page 2, & you should see the status of the receiver signal. The system WILL NOT let you record w/o a GPS signal!!!!!
Don't be surprised when you loose your signal more frequently w/ some non JD receivers.
Good luck | |
