Posted 11/14/2006 08:17 (#61443 - in reply to #61236) Subject: RE: 1460 grain bed augers.....
If you are planning on using this combine for several more seasons I would take the counter shaft out also that drives the augers. It gives you a good look at the bearing on the right side behind the drive pulley. With the counter shaft out the augers will slide to the rear and the roll pins are easy to remove. All the bearings, augers, gears and shaft are hex and usually slide freely. Good luck
Bob
