Search Forums | Classifieds (87) | Skins | Language
Duals on 2+2 IH
boog
Posted 11/15/2006 08:05 (#61788 - in reply to #61783)
Subject: Re: Duals on 2+2 IH
Except on the "Super 70s" if you mounted duals on all fours you had to put stops in the turn cylinders. Otherwise if you turned tight the duals would get into each other. Friend ran duals on the rear of his 3788, said it helped the ride but didn't do much for traction as the tractor had enough without the duals. This was back when they were new.
WE demoed a new 3588 & it rode terrible - rocked side to side on rough ground. I can see the reasoning for duals on the rear.
Edited by boog 11/15/2006 08:06
