NE SD | No problem. All you can do is try loading it, and if it works it works. If not, like you say you can just load them on the back of the mover and run them forward. If you are only going to go two or even three high, I don't think you'll have any trouble with picking them up or unloading them. One thing you will need is a decent tractor on the front. Our 4255 mfd is pretty much the minimum for that amount of hay. Cousin who shares it with us used his 8640 for years rather than a 4450 2wd. He now uses an 8110mfd and says it works well. | |
