Search Forums | Classifieds (52) | Skins | Language
GS2 Harness for Non JD Sprayer
BCINMN
Posted 12/14/2006 11:40 (#73685 - in reply to #73304)
Subject: RE: GS2 Harness for Non JD Sprayer
Here is the kit I would buy, PF90254.
I think it includes GPS mounting bar, transient voltage protection and power adapter harness. It also has the JD implement connector portion, you may not need this, but I think you would if you wanted to use Swath Control Pro.
There is a lower cost kit if you do not need the implement connector, I think it is PF90420.
You will also need a Original Harness to GS2 adapter PF80773, you probably already have this from your 9760.
As far as the ATU kit, what model spraycoup, looks like it could be supplemental kit D or K depending on spraycoup model.
