NCIL | I would stay with Deere and run passive guidance. Works good with fixed frame tractors. I have not heard of good results with 9R/RX tractors. SF6000 receivers are relatively cheap right now but the concern would be if you dealer will continue to support their tower network. You could also put up your own base stations if needed. The 4640 will get you autopath and boundary track and is much more user friendly than the 2630 imo. Will have to pay for automation 4.0 each year unless you can get a European model. 4640 are also cheaper now that the gen 5 is out. There are some good deals on FB market place. | |
