Caledonia, MN | https://portal.agleader.com/community/s/article/1303?language=en_US
this is the ag leader knowledge base article that "helped me " get my 3200 planter to show singulation skips etc.
You have to have the new sensors, dual boot. It says that an older sensor will work but if they have blue ends I found they will not show singulation etc. When you scroll through sensors you can check each one to make sure they have a good baud rate. I had one that would be ok for a few minutes and everything would work but when it would flake out " low baud rate" I would lose singulation on monitor.
Also Need to use an Incommand 1200 | |
