| yep, it works...
I made a cable and connected Amatron computer with P6 port on tmx... it only uses two wires, signal and ground...
I got the signal from tmx, but it seems inaccurate...
my equipement is in kilometers, not miles, so that value you wrote does not fit...
now I should play with settings to get correct speed....
as you mentioned it is combination of Hz setting on trimble and impuls/100m setting on Amatron....
my Amatron is currently on 9600 imp/100m, which fits novatel receiver, originaly came with amatron, but I have also used it with GPS speed sensor which was set on 12000 imp/100m, and both setups always match speed from GPS NMEA...
maybe there is some default value for that configuration, for example for correct speed you should set 10000 imp/100m on implement and 50 Hz on trimble??? otherwise I must search for correct settings, and maybe not match 100 % correct speed...
