West Central MN | I don't, but I can get some. Mine is actually an old montag box, but the principle would be the same. Find a spot where the motor can be mounted to drive one of your sprockets that used to be ground drive. I like doing it that way because if you have any "technical difficulties" you can just remove the chain from the hydraulic drive, and reinstall the ground drive chain. I did the same thing to my neighbors air seeder cart too. | |
