| I just purchased a John Deere 1790 16-31 row planter. It's a 2004 with the original seed star system and 2 hydraulic drive meters (one for each half of the planter)
Is it possible to variable rate seed and use half width shut off using a 2600 gps with swath control in combination with a GS2 rate controller?
Also, the planter has a liquid kit (ground drive John blue pump). I plan to add a hydraulic motor with electric control to variable rate liquid as well. Will my GS2 rate controller and 2600 be able to variable rate the liquid system in combination with variable rating seed and section command? | |
