| Can it be done? How?
AgLeader will not make a platform kit for our 2012 JD8310RT. We are buying a JD 4640 display and a JD receiver new for $10,000 + $1,500/yr for RTK signal. If I can run on Cat 765B I would buy two of these systems. WE plant with a CaseIH 1200 3pt 31R15"stack fold on the 8310RT and need to precision cultivate with the Cat765B. I am unaware if someone has software to convert a Deere guidance line to AgLeader guidance due to what each system uses as North? So now were heading to Deere guidance. Would like to be an the same guidance system as cultivation is mission critical.
Thanks in Advance,
Mark | |
