Jeffersonville, OH | smallchev - 3/18/2024 15:51
Is there a place to look up stuff somewhere? I can find up to 16 row. I need a seed sensor harness for a white 8500 24 row 22" to the 37 pin connector. No row clutches. Thanks
So, if you need the harness to go from seed sensors to the STMM adapter, then here's the factory part number for a 24R22" for an older White planter using that same frame...N856885. John Schmidt & Sons in Mt Hope Kansas still shows one in stock.
I typically go that way, then all the legs are the right length on the harness. After that, you just need the STMM to Dickey John sensor harness from Ag Leader, or Sensor-1, Ag-Express, etc.
Sensor 1 part number for that Harness is HAGLEADER-24
Those 2 harnesses should get you to the STMM and ready to go
Other than that, you can order a 24 row harness from Ag Express, Sensor 1, etc...but you'll have to tell them harness lengths for each row.
Chris |
