Southern Illinois | So to keep the pro700 from telling you the product control is missing, the best solution is to reconnect the boom and product node. You would just need power ground and can so the pro700 sees a complete sprayer setup. You can even leave the boom switch inputs connected so it sees the coverage area. You just don't activate the product on the pro700 so it never expects to spray anything.
The one way I know if to make it not alarm for the lack of sensors on the autoboom would beb to unplug the autoboom node when the toolbar is being used and plug it back in for the spray bar.
Or you could replace the autoboom node with a raven ISO bus autoboom node and then run it through the AgLeader isobus.
Just some thoughts. | |
