Ionia Co. Michigan | As cheap as generics are currently just use a straight shot of gly. No worries of the diesel being where it shouldnt be. I believe there is a cut bark part in the label anyway correct me if I am wrong. Wont take more than a quart or two depending on size and amount of trees. Put it in a pump sprayer with a little food coloring to see which trees have been treated. A couple inches wetted around the perimeter of the stump will do it. Do it same day as cut before trees start to try healing. | |
