Jeffersonville, OH | I still have a couple of the older Steer Command here, and some Z2 in stock...depending on what tractor we are putting it on, or what the customer wants the system to do, is which direction I will push them.
If you have an older series tractor, that probably isn't going to get software changes like is posted above, and are not worried about Turn Path/ Auto turn, then the older Steer Command is a fine option. If it's a brand new unit, or the customer thinks he might want to enable Turn Path, or something else Ag Leader might think up, then I would direct them to Z2.
Chris | |
