set up fjdynamics
hardknocks
Posted 4/11/2024 00:43 (#10702425 - in reply to #10701563)
Subject: RE: set up fjdynamics
southern Illinois
I’ve got it measured as close as I possibly can from antenna to center of axle. It not easy get that number I should be real close. It wanted inside width of front tires and center of axle to front of weights, axle to axle, center of axle to center of drawbar hole. Height of antenna. I got them as close as I possible can the one from antenna to outside of axle was confusing. Because of that’s not outside of tractor the duals are. Of course auto steer is all new to me so I’m learning
I didn’t get a power cord. I got battery charger and 12volt leads with clamps to go to a 12 volt battery.
Wa going to put base station at house with the radio. And put the one antenna about 35-40’ foot in the air hoping I can get signal to my fields
