North central Iowa | Having trouble calibrating auto-steer on CIH215. Took off sensor on top of kingpin and was able to turn the hex shaft counter-clockwise easily with my fingers, but turning clockwise it seems to tighten down. I am guessing it should be stationary and only turn with the king pin. Is something loose inside the hub or is the hex shaft need to be tightened to a certain torque?
(Kingpin shaft (full).jpg)
Attachments ---------------- Kingpin shaft (full).jpg (247KB - 3 downloads)
