Victoria Township, North Dakota | I traded my 43 gpa 765B with 5 SCVs for an 835B with the 59gpa pump.
Given:
Gen 2 2020 seed sense
My planter has 6 hydraulic circuts. As follows:
1)Two vac fans
2)Tounge lift
3)Fold for the bar.
4)2x2 fertilizer hydraulic drive controlled by a GS2 rate controller on my 4640 Gen4 screen.
5)Deltaforce
6)CCS and hydraulic infurrow fertilizer and deltaforce alternator engaged when I lower the planter and lock it forward.
When I ran it with my 765B I would unplug the 2x2 fertilizer hydraulic hoses and plug in the fold hoses when I needed to fold the bar to move between fields.
I only have 5 SCVs on the 835B but I do have a power beyond outlets and a load sense fitting see the attached photo.
Question: if I plug the deltaforce into the top power beyond outlets and I have an SCV like my raise and lower engaged fully open to 100 percent will the deltaforce get the 6 gpa at 2500ish psi without over heating the tractor hydraulic oil?
(20240420_124937 (full).jpg)
Attachments ---------------- 20240420_124937 (full).jpg (153KB - 4 downloads)
