Front mount tank
Glenn W.
Posted 4/25/2024 13:57 (#10717603 - in reply to #10717548)
Subject: RE: Front mount tank
Southeast Washington
I would just put a check valve on the line to the planter so you could just turn on the power as needed. If filling the front tank from the back just tee in a line around the check valve and pump so the tank could be filled by just opening a valve on the teed off line.
