Posted 10/16/2007 21:19 (#220749 - in reply to #220692) Subject: Re: Your thoughts on magnesium Lime
Martinsville, Ohio
I spread it on top, I don't work ground unless absolutely necessary and only when my soil test recommends magnesium lime.
Many will disagree, work it and use the cheapest source of lime.
I use mag lime because my soil tests are high in calcium and low in magnesium. You get under 15% base saturation on my soil tests and you can see yields taper off.
