Search Forums | Classifieds (53) | Skins | Language
Insight Direct Command in a Patriot SPX3185?? Ted/Tom???
DG N. AL
Posted 12/23/2007 16:51 (#266938)
Subject: Insight Direct Command in a Patriot SPX3185?? Ted/Tom???
Hillsboro, AL
I will be installing a control system in a Patriot SPX3185 soon. I intend to install a Trimble NavII/Insight system. We will use product control and auto swath along with auto pilot. The Patriot currently has a Raven SCS 460 in it.
    * Will this install require the Direct Command switch box (SC110)? I would rather use the switches on the Patriot for boom control. I think I have read that you can plug the Insight directly into the Raven harness and go. I hope this is the case, because I want to be able to reinstall the Raven and use it during the time the Insight is in the planter tractor for planter logging.
    * Will auto swath work without the SC110?
Has anyone heard any sneak previews about Trimble’s January releases?
    * Will they be releasing anything with the data logging capabilities to match the InSight?
    * Anything like Seed Command or Direct Command coming from them?
