Raven Smartrac
Applicator
Posted 12/31/2007 07:03 (#271770 - in reply to #270814)
Subject: Re: Raven Smartrac
The tilt sensor will work for a very slow change, like a hillside(where you might want it to not work). If you have a wheel drop into a hole, I doubt that it will react quick enough. If you need HP precision, you probably need the Enhancer. You might get a 100% for the tilt sensor as a trade-in for an Enhancer, can't hurt to ask. One thing you get with Raven is the best factory support in the industry. You can talk to someone who knows the product. If you have the time, it might be a good idea to wait until mid February. The two biggest farms shows are then and one of the precision outfits usually tries to drop a bomb on its competition there.
