| The nice thing about a drone is you have the option to go up. Which means you can position the subject of the picture below you, allowing you to cut out the horizon. Also, try changing the exposure point which is done by tapping on the screen. For best results, tap on the darkest part of the screen, or the subject of the picture. You may lose some quality, but when the camera compensates for the brightness, it makes everything else much darker. Changing the exposure point over rides that automation and you can get fantastic shots. | |
