| We have a 2 outlet Fasse on our 4430 to give us a total of 3 sets. Has worked really well. We have the little switch mounted on the control lever so sometime you can pull the lever to move one cylinder and then just press the button to move the other one without letting go of the lever. Can work pretty slick, depending on your machine.
A couple of disadvantages:
1. neither SCV will work if you have no power
2. we can't hook up hoses under pressure
3. only available with Pioneer couplers (may be an advantage if you don't have any of the old JD couplers anymore) | |
