Posted 11/7/2006 04:14 (#58799 - in reply to #58792) Subject: RE: Tension pins??
Huntley Montana
Can you put a lift assist wheels on the back & just us the lower links of the Muder F*** to lift the front? That way you will have some weight transfer if needed. Might also use the center link if you have the right lift assist setup to help lift on the ends.
