NW MN | If you have the newest switchbox, the Aux input Module is built into it. The harness included that connects to the short lead that comes off the switchbox will have the same connectors on it as the module. Plug into those connectors as the diagram shows to plug into the AIM.
If you are not running a machine with factory switches you want to use, the round 4-pin CAN A connector with the metal clip is the only one you need to plug in. | |
