| Can you list the receivers and what activations they have? SF7000 has SF-RTK, not SF3. That will help us tell you the arrangement that works best.
For instance, I have an SF6000 with RTK going on the tractor and SF7000 with SF1 for the planter. That will work.
At one time, I had a 3000 with RTK for the tractor, and 6000 for the planter. Dealer said that would work, but advised moving the RTK to the 6000 since the RTKx is a much better option than SF2 fallback would be. I did so, and that worked well. | |
